FGEN Radar Pulse
Hey everyone, I am really stumped at how to do this in LabVIEW. I have to generate a signal as described in the requirements document.
Test Conditions
(1) Uplink frequency 5800 MHz
(2) Interrogate with 2 pulses, 5 μs leading edge to leading edge
(3) Downlink frequency 5700 MHz
(4) Repetition rate 1000 pps
c. Test Method
(1) Interrogate the transponder with the above conditions with interrogate PW of 0.25,
0.50, and 1 μs.
(2) Record the sensitivity for each PW/.
I am not well versed in signal generation but i have tried many of the examples and I even tried generating my own waveform but when I tried writing it to the function generator NI PXI-5421 i get errors stating that the rate is incorrect.
Maybe I am reading this incorrectly but to me it saying create a waveform that has two pulses with varying widths and repeat this waveform at a 1000 pps rate (1kHz).
I have tried so many different things but just cant seem to get it right.
Can any of you point me in the right direction of how to go about doing this?
I know some of you will say show us the VI or what you have done, but at this point i have tried too many different things it is best just punt and start from scratch.
Joe.
"NOTHING IS EVER EASY"
Message 1 of 1
(786 Views)
