FGV With Array
Hello readers, so what I am trying to create is or should be pretty simple. I am trying to use this FGV as a way to write and read for four different indexes. Not sure if this should be that easy as instead to have four different FGV to do the same thing just base on the indexes.
(3,171 Views)
Hi A3,
What is your question?
Why don't you use an array inside your FGV? Why do you need to hold 4 different bool values in 4 shift registers in (probably) 4 cases of y case structure???
Hint: we cannot debug/edit/run images in LabVIEW…
(3,154 Views)
I'm assuming that all of your "Channel" cases are all the same. This is not ideal.
If you find yourself repeating code with little or no differences, always consider rethinking the problem.
As much as I like spaghetti, it doesn't go well with software (error prone and hard to maintain).
Check out the attached code (LabVIEW 2018).
On first call it initializes an array then performs the requested action.
Founding (and only) member of AUITA - the Anti UI Thread Association.
(3,100 Views)
I'd make it an array internally and just index in/out one.
Qestit Systems
Certified-LabVIEW-Developer
(3,081 Views)
Actually this is what I wanted it. I figured it out after posting this.
(3,066 Views)
That'll work, but if you just make it an ordinary array you can skip the inner case structure altogether.
Qestit Systems
(3,054 Views)
