FIFO-Host to target(DMA)
Where i can find the infomation about. Host toTarget(DMA) FIFO(if possible with example ). I have use Target to Hoat(DMA).
(4,379 Views)
Hi Barla,
Below are several articles which contain useful information on DMA FIFOs.
Writing to DMA FIFOs from Host VIs (FPGA Interface)
Using DMA FIFO to Develop High-Speed Data Acquistion Applications for Reconfigurable I/O Devices
There should also be examples available in the LabVIEW Example Finder under the Hardware Input and Output tab.
I hope you find this response useful.
Steve
(4,355 Views)
