FIFO Labview FPGA, plot values on a graphic
I'm using a cRIO 9039. I have a sensor that sends very speed pulses, with a time of 45 us. I try to plot this values on a graph to analyse them. I try to find an example of FIFO on "NI Example Finder". However I found only sinus created and sent to the computer. I didn't arrive to change to put the analog input. Maybe somone can help me to say where there is an example with an input of the cRIO.
I found this example to https://learn-cf.ni.com/teach/riodevguide/code/fpga-pc_dma-fifo.html
It seems good but I can't run it I don't know why.
Thank you for your help.
Leo
(1,743 Views)
Now, I found in the examples a "Data transfer and storage" code. In it a sinus is created to send to the graph, however I can't change it to put an input of the cRIO.
(1,715 Views)
