FIR compiler for begginers
Hi all!
i'm new to FPGA , and i have a VI (i did not program it) that uses the FIR Vi to fliter an array of waveforms. i'm trying to re-write that VI in FPGA
instead of an array of 9 diffrent waveforms i have 9 diffrent 1D arrays (Each elamnt in the arrays is FXP (24,7))
i tried to save the filter data from the original VI to a txt file, then to make it into a .coe file, and to use this file with the 7.1 FIR compiler
all i get after i do all the neccery conversions (from FXP to array of BOL for each point of data) is a False array, like nothing have happend
some expermints have thought me that issue may lay with the ACLK input of the FIR compiler VI, but i have no clew what am i doing wrong?
Any help (or hint's. or relvent data sheets/manuals/white papers) would be helpful
thanks in advance 🙂
Message 1 of 9
(9,323 Views)
I was able to find some potentially relevant resources on FIR that might be helpful as you debug:
Working with LabVIEW Filtering VIs and the LabVIEW Digital Filter Design Toolkit VIs
http://www.ni.com/white-paper/4851/en/
FIR Filter VI
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/vi-lib/analysis/3filter-llb/fir-filter-vi....
Teaching FIR Filter Design Using the Digital Filter Design Toolkit (Windowing)
http://www.ni.com/white-paper/4240/en/
Getting Started with the NI LabVIEW Digital Filter Design Toolkit
https://www.ni.com/pdf/labview/us/final_dfd_tutorial.pdf
Good luck!
Message 2 of 9
(9,229 Views)
An example VI with the FIR Compiler 7.x block in a SCTL, wired to IQ data would be sublime.
cc
Message 3 of 9
(8,946 Views)
I found such an example. It is in the High Throughput FPGA course though, exercise 5-1.
cc
Message 4 of 9
(8,873 Views)
How you do it anyways? I can't understand where you aclk signal should be connected to
Message 5 of 9
(8,264 Views)
Are you talking about the Xilinx IP in LabVIEW, FIR Compiler 7.x block?
cc
Message 6 of 9
(8,253 Views)
Yes, the Fir compiler 7.2 to be exact!!!
Message 7 of 9
(8,245 Views)
I do not think the aclk signal needs to be connected.
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
Message 8 of 9
(7,990 Views)
it's been a while, but can someone post the exercise 5.1?
Thank you.
Message 9 of 9
(7,115 Views)
