FIt to text string control
 I w ould like to know if theres is a VI or a property node on a string control wich could make the size of the string control fit to text only when the user click on it and try to modify text then the size of the string control must take is original size back.
thanks
Olivier
(2,770 Views)
In Labview 8.2 it's an example that does something similar to what you want.
The name of the example it's "Size to text for string control.vi"
Software developer
www.mcm-electronics.com
PORTUGAL
(2,760 Views)
