FLIR A300
I have i flir A 300 series and thermovision Labview toolkit V3.3 on Labview 2011.  I would like to acquire a temperature array from the camera with toolkit.
I open the connection with specific camera, ethernt 16 bit , IP address and in a while loop acquire the Image with Digitalgetimage.
The problem is the Digitalgetimage return empty array and timeout.
Can someone help me ?
thanks in advance.
(3,789 Views)
Hello
Are there any out-of -the box examples shipped with the toolkit? Do those work for you?
Have you tried to change the Image Mode/ImageType, or slow down the acquisition?
(3,713 Views)
The examples of toolkit dosent work. Im look in deep inside of VI, the timeout arrive from getimage subvi. I can read and write camera prameter but i receive an error only to acquire image.. I tryed to change image type and other but the result is the same : timeout 😞
(3,701 Views)
Have you given a look to this forum discussion?
http://forums.ni.com/t5/Machine-Vision/FLIR-sc655-and-ThermoVision-Labview-Toolkit/td-p/2255142
Maybe if it can be useful to you too
Unfortunately I don't have neither the hardware nor the thermovision toolkit so I can't try it on my own
(3,692 Views)
