09-30-2005 05:23 AM
09-30-2005 07:49 AM
You probably should find a book on the basics of RF communications. You have a number of problems with what you are proposing, with the software end being the least of them. First, the 6014 card has only a 200 KS/s rate, meaning the highest frequency that you could look at would be less that 100 KHz. Secondly, unless the signal were very strong you would not be able to detect them with the input sensitivity available. There are an almost infinite number of other issues that you have to deal with before you start thinking about whether you can do the demodulation in LabVIEW.
P.M.
09-30-2005
08:07 AM
- last edited on
08-11-2026
08:42 AM
by
Content Cleaner
