FM of square wave
I have to generate frequency modulated square wave and feed it to DAQ card. I could generate FM of sine wave and figured out how to convert that to square wave. The issue is that ouput of modulator is 3 element type and can be only fed to waveform generator. So i cant use that output for further calculations or sending to DAQ.
Please if anyone can suggest any procedure to carry out the task.
Sid
(3,354 Views)
Sid,
I am not completely understanding your problem.  Please post your VI. Show where the incompatibility in datatypes is.
Lynn
(3,343 Views)
Did you see this shipping example in 2013?
C:\Program Files (x86)\National Instruments\LabVIEW 2013\examples\Signal Processing\Signal Generation\Function Generator with FM.vi
You can choose between sine or squarewave.
Barp - Control, Simulation, RTT and HIL - National Instruments
(3,301 Views)
