FM signal demodulation
hi all, i have one project here, but i no idea how to do it. the question is as below:
using computer simulation, demonstrate that an FM signal can be demodulated using:
a. slope detection
b. a zero crossing detector
help...
p/s: i am using labview 8.5
(2,996 Views)
Do you have to simulate it, e.g. make a nice graphical demonstration that
uses a nice simulated signal? Or you need to get real FM data from the
ether?
What hardware do you plan to use?
Do you have any data you can send?
Once you get the signal, you should be able to simply get all zero
crossings, and the distance between them is an indicator of the signal's
frequency.
Same goes for the slope detection, although that seems to be a bit more
difficult.
(2,962 Views)
it is just software program. no hardware is need. the input is simulation of FM signal and the output is graphical presentation.
(2,958 Views)
