FOC of induction motor -FPGA
Hello!
I want to implement a control method of an induction motor - a FOC method or U/f method using LABVIEW FPGA.
I have a PCI-7831R data acquisition board and A SCB-68 Connector Block.
My induction motor is small: 0.18kW, I have s current sensors and an encoder...
I have simulation of  control methods in Matlab-Simulink, but I want to implement those methods in Labview.
I need help!!
Thanks.
Adi
(4,178 Views)
Greetings Adi.
While my knowledge of such control methods is limited, and I'm unsure of what the U/f method is, there are a couple of articles in the DevZone that may be of some benefit.  I have linked them below.  I hope this helps!
FPGA Powered NI CompactRIO Controls Industrial Motors using Field Oriented Control (FOC)
Field-Oriented Controller (FOC) / Space-Vector Controller for a Brushless DC Motor
Michael G
Michael G.
Self-realization: I was thinking of the immortal words of Socrates, who said, "... I drank what?"
(4,151 Views)
Hi Michael, I'm working on the project about BLDC motor control with FOC method through cRIO-9047. The link "FPGA Powered NI CompactRIO Controls Industrial Motors using Field Oriented Control (FOC)" you post was over data.Could you provide the information and update the link address, thank you very much.
(2,800 Views)
