FOR loop termination?
Is there any way in LabView to terminate FOR loop from the inside
before it executes N times? Something like "break" instruction in C. It
seem like a simple question, but I couldn't find a simple solution :-).
thanks,
chris
Message 1 of 10
(5,087 Views)
Is there any reason not to use a While Loop? If you use
this kind of loop you can stop it when you want.
Best Regards
Gorka
* Sent from AltaVista http://www.altavista.com Where you can also find related Web Pages, Images, Audios, Videos, News, and Shopping. Smart is Beautiful
Message 2 of 10
(5,085 Views)
I have a need to break out of a FOR loop that is using auto-indexing. I have a
IF-THEN in the loop with a null ELSE clause, but I hate to run a few thousand
null loops just to exit "early."
Randall Miller
Message 5 of 10
(5,085 Views)
> Randall Miller
To answer the original question there is not a way to break out of a "For Loop".
The solution above (or similar) is all that is available.
Kevin Kent
Message 7 of 10
(5,085 Views)
yes it is,
sometimes I need to run the loop 0 times. While Loop runs at lest one time, as the condition is checked at the end of the loop. One can build the logic to
run a While Loop 0 times, but in my case design becomes pretty complicated.
In other words I can accomplish what I want, but I hoped to simplify my VI.
best regards,
chris
> Best Regards
> Gorka
Message 3 of 10
(5,085 Views)
In article <39367174.217C9614@alf.ifj.edu.pl>,
chris szybinski wrote:
>yes it is,
>best regards,
>chris
Perhaps you could put a select comparison function in there and send the
results to the loop? WHile false, it will not run, and while true, it
will. Just a thought without any background into your program.
Harry
Message 4 of 10
(5,085 Views)
this is exactly what I've done :-). But it would be much easier to be able to break the loop.
chris
> >yes it is,
> >best regards,
> >chris
> will. Just a tho
> Harry
Message 6 of 10
(5,084 Views)
I know this is not exactly what you are asking for, but I will mention it anyway.
There are two ways to stop a For Loop. The first is to use the auto-index like you are doing. The other is to wire a value to the N input before starting the
loop. The loop will stop on the first occurence of EITHER of these methods. If you want the convenience of auto-indexing, but know that you will not want to
process all of the values in the array, try to determine the quantity before entering the loop. Then wire that value to the N input. A value of 0 will prevent
any iterations of the loop from executing.
Good luck.
Michael Munroe Mailto:mmunroe@abcdefirm.com
A Better Complete Development Engineering Firm
San Mateo, CA 94403 ht
tp://www.abcdefirm.com
> chris
> > >yes it is,
> > >best regards,
> > >chris
> > Harry
Michael Munroe, CLD, CTD, MCP
Automate 1M+ VI Search, Sort and Edit operations with Property Inspector 5.1, now with a new Interactive Window Manager!
Now supports full project automation using one-click custom macros or CLI.
Message 8 of 10
(5,084 Views)
CTRL period will stop the program.
In article <39354B52.49F41576@alf.ifj.edu.pl>, szybinsk@alf.ifj.edu.pl says...
>thanks,
>chris
Message 9 of 10
(5,084 Views)
Okay, but I think the poster wanted to stop the loop when a condition was
met without stopping the program. In that case (at least from a purist CS
point of view), a while loop would be a better construction, using two guards
joined by an OR operator: one that stops the loops after a given number of
iteration, and the other that stops the loop if a condition is met.
-Asher
says...>>>>Is there any way in LabView to terminate FOR loop from the inside>>before
it executes N times? Something like "break" instruction in C. It>>seem like
a simple question, but I couldn't find a simple solution :-).>
>thanks,>>chris>>>
Message 10 of 10
(5,084 Views)
