FOR loop
Hy guys.
I started programming in LabVIEW, but I got stuck. I would like to compare every two consecutive element of an array. I started to do this in a for loop, but I don't know how to get the two consevutive element.
Could you help me out?
P.s: My really task is: I have an 10 different data in a file but they appear in the file more then 1 time and I have to write those 10 data in an array. The following program contain's the idea how I thinked that I can resolve it.
(3,912 Views)
Accepted by topic author Dombi_Kristóf
For consecutive elements use the first case.
The second one removes all duplicates.
(3,905 Views)
Thank you. It was really helpful.
Can I have one more question...? What did you wiring for the output, array3, when the case structure is FALSE? Many times I wanted to use the CASE stucture without wiring the FALSE part, but I can't do that.
(3,890 Views)
Hi Dombi,
IF false THEN dont change array data
How to not change array data? Just wire them…
(3,886 Views)
Hi Kristóf!
Not entirely sure what you are trying to achieve, but I may have a relevant example lying around.
This VI generates an array from the given elements "Options" in a way that no element is chosen twice. Have a look at the algorithm, you may find it useful!
Cheers!
(3,807 Views)
