FOSCAM cameras and Labview
Hi everyone!
I´m trying to use a pair of FOSCAM cameras with LabViEW, but I haven´t been able to connect this cameras with the software. Do you have any idea on how to connect them with LabVIEW and how to control them? It would be great if you could help me.
(4,605 Views)
Does this camera show up in NI MAX and Device Manager?
-Check whether you have Camera file, if not obtain one. Read more on:https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YI74CAG&l=en-US
uday
(4,556 Views)
Hi!
First thing to do, install NI Vision drivers:
NI Vision Acquisition Software
https://www.ni.com/en-us/shop/product/vision-acquisition-software.html
But first you need to determine which of the three drivers that come with VAS you will need to know if youneed a license:
What Is the Difference Between NI-IMAQ, NI-IMAQdx, and NI-IMAQ I/O?
https://www.ni.com/en/support/documentation/compatibility/25/ni-vision-driver-and-vision-acquisition...
Finally, you may need to determine first if you require a previous version depending on your LabVIEW version
NI-IMAQdx Compatibility with Different LabVIEW Versions
https://www.ni.com/en/support/documentation/compatibility/17/vision-acquisition-software-and-labview...
Hope this helps,
Daniel C.
(4,549 Views)
I'm trying to connect Foscam camera and capture Image applications. Have you found any solution to connect Foscam camera through LabVIEW?
Thanks in Advance
(4,039 Views)
Hello
You should ask the vendor if this camera supports the standards that the link below supports
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P6COSA0
The link shows the driver list so if the camera does not support those standards the drivers cannot connect with the hardware.
Additional information:
https://forums.ni.com/t5/LabVIEW/How-to-control-and-display-video-from-IP-camera-using-ActiveX/td-p/...
Regards
(4,021 Views)
