FP controls: Can name of superclass be obtained?
Refnum to FP control can be used to obtain the class name (property Class Name). Is there any way to obtain name(s) or superclass(es)?
In this example the Class Name indicator always shows Enum. Can NamedNumeric (and probably Numeric and Control) be obtained?
Thank you
_____________________________________
www.azinterface.net - Interface-based multiple inheritance for LabVIEW OOP
(1,137 Views)
Accepted by topic author _Y_
This can be done via the Get Class Hierarchy from Class Name.vi that's in the VI Scripting palette if you have scripting enabled
(1,098 Views)
