FPGA : Accumulator DSP48E or DSP48E1
I’m looking to do an accumulator in FPGA.
So, i used FPGA box with array inputs to test methods.
First, I did 3 Methods and I have same results.
Then, I tried to used DSP48E or DSP48E1 as Accumulator
I look on this page, how I need to configure DSP.
https://zone.ni.com/reference/en-XX/help/372614J-01/lvfpgaconcepts/dsp48e_function/
The problem, is it doesn't work.
Anyone can look and explain why ?
Thanks in avance
(1,824 Views)
Why don't you use the Xilinx IPCore for an accumulator?
(1,807 Views)
That's the next step.
I never used IP core
(1,800 Views)
I would say it's a lot easier than trying to use the general-purpose DSP node. That thing is an absolute nightmare to understand and configure.
(1,789 Views)
Unless there is a performance need, I would use math primitives.  Optimization on an FPGA can be very costly in terms of development time.
See also https://www.ni.com/en-us/support/documentation/supplemental/11/an-introduction-to-high-throughput-ds...
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(1,769 Views)
Thanks all,
I achieved Xilinx IP accumulator successful.
It’s right that it is more easy than DSP48.
Next step is to do accumulator with input array of 2 value… (N and N+1)
(1,726 Views)
