FPGA Application not running on CRio-9045
I did a simple VI to read and write Digital inputs/outpus with fpga mode on Crio-9045, but it didn't work ( I can't see switching inputs and there isn't an error, even i wanted to turn on the FPGA LED an it didn't work). I compiled the FPGA VI and it completed successfully.
bellow you find the  FPGA VI block diagram and the HOST VI block Diagram
I use CRIO-9045
-Module NI 9472
-Module NI 9215
-Module NI 9421
thx.
(1,881 Views)
Hi bill,
what happens when you "Run" the FPGA VI after you call this "Reset" node?
(1,868 Views)
Accepted by topic author bill0w
Hi gredw,
I found the problem. because I changed the order of the modules in their slots. it's weird when running i don't get any error and in the project don't automatically update the module location.
Best regards
(1,839 Views)
