FPGA CLIP error
Hi!
I'm trying to use VHDL code as CLIP component (following this tutorial here). After compiling on FPGA I get bunch of warnings and errors and after executing it on computer the output goes nuts (rapidly changes).
I included XilinxLog file
(2,578 Views)
Good Morning VeA,
Do you think you could include a screen shot of the window that shows the errors after you are done compiling?  Also, take a look at this document, make sure that these were the steps you followed in setting up your VHDL as a CLIP component.  I hope this helps!
-Cody C
(2,530 Views)
