FPGA CS Line
Hi all,
First of all I've attached code and the instrument I am trying to communicate with. The main goal of this project is to read the FIFOs from the board. I've set digital outputs of a myRIO-1900 to SCLK, MISO, MOSI, and CS0.
It's my understanding that the chip select line should only drive high after a command has been written to the device. I have wired up waveform charts to show DIO activity in the FPGA code which I have screenshot of as well attached. I would think that the CS should drive up periodically but it seems that it is "sporadic" if you will. It does not look uniform.
It should drive up after 2 U8 bytes are clocked in by the SCK. Am I doing something wrong in the FPGA? Is this normal operation?
Thank you.
(2,060 Views)
It is completely unclear (to me) what you are doing, and what you are trying to do.  I presume you already know that the myRIO is a perfectly-capable "SPI Master" -- the myRIO Software Toolkit even comes with Express VIs that implement two independent SPI Master devices using the DIO Lines on MXP A and B connectors.  Do a Web Search for myRIO SPI for a useful Video of how to do this.
Bob Schor
(2,016 Views)
Just trying to communicate with my device I'll give a look over what you recommended.
Thanks Bobby.
(2,013 Views)
