FPGA Compilation Fails due to Xilinx Error
Did some more testing and when i;m not using a hybrid solution (Scan Engine and custom FPGA code) but just a custom FPGA the compilation works.
So it seems to be caused by the hybrid mode...
Message 11 of 12
(2,237 Views)
Hey All,
There is a known issue with LV FPGA 2014 and CompactRIO 14.5 for the 903x controlers. Our recommended install is to match your released RIO version to your LV install, until a later compatible release comes out. Typically SP1 release of RIO is not recommended with non-SP1 LabVIEW. It may work just fine but this was one instance where some resources got moved.
If you are using DMA Fifos (scan engine uses 2) in a fpga bitfile and you have mixed software, you will see this compilation error. The fix is to upgrade all software to SP1 or install CompactRIO 14.0.1.
http://digital.ni.com/public.nsf/allkb/CBBA45652681AF5E86257D7400508DB3
Kyle Hartley
Senior Embedded Software Engineer
Message 12 of 12
(2,219 Views)
