FPGA Compile server error
Hi all,
I am trying to compile the FPGA VI but the compile server stops with this error message;
ERROR: sim - Component_Name: The name cannot have more than one consecutive '_'
Finished Regenerating.
ERROR: sim: 57 - Error found during regeneration.
I have also attached the jpeg file showing the error. Can anyone tell what this error means?
(2,719 Views)
Sandee,
That is quite a strange error.  Can you verify the status of the compile server before trying to compile?  Look at Start Menu » Program Files » Nat'l Inst. » FPGA » Compile Worker.  Also, how do you have the compile server configured in LabVIEW? Look at Tools » FPGA Module Options... Are you trying to simulate an FPGA or compile to physical hardware?
Since this is a Xilinx thrown error, you may also try repairing the installation of the Xilinx Tools software.  You can look at the following link to verify you have the correct version installed:
http://digital.ni.com/public.nsf/allkb/ed6fc9cf7b983cfd86256dce0072e313?OpenDocument
(2,699 Views)
