FPGA Compiler Bug
Great! Please drop my name in the service request and hopefully it will get escalated to me quickly.
My quick status: I got a 2020 stack set up to try to reproduce the original issue on this thread. I only had a sbrio around so chopped out the IO but that did not reproduce the issue so I'm hunting down a 9035 and 9853 to borrow. I did briefly scan through the generated code from the original project and nothing immediately jumped out as wrong but I'll keep digging.
Message 11 of 12
(509 Views)
Name dropped! Hopefully you have access to an sbRIO 9651... You should be able to run our code on the evaluation board. We tried to remove the IO nodes but the problem disappeared in our case, too.
Thanks!
Message 12 of 12
(493 Views)
