FPGA - Convolution interleaver
Can anyone help me in understating the logic of convolution interleaver in labview FPGA
(without inbuilt function[ci])
(4,689 Views)
Hi Harish,
please provide an example VI to illustrate your problem!
(And please don't spam me/us with private messages. Post your questions in the public board!)
(4,615 Views)
i didnt have any vi i just asked the concept in fpga
(4,600 Views)
Which concept?
More input required.
(4,596 Views)
I am relatively proficient with LabVIEW FPGA but any built-in function called convolution interleaver is unknown to me. I am however not even familiar with the concept.
I Googled it and found this page: https://surf-vhdl.com/how-to-implement-a-convolutional-interleaver/
Is this what you are asking for? If I understand correctly a convolution interleaver rearranges the bit order before streaming the data on some communication link in order to make the communication link less receptible to errors. Implementing such a technique in LabVIEW FPGA is quite doable, one could even just follow the VHDL code provided in the link.
But I am afraid I don’t have any solution to share.
(4,589 Views)
in normal labview we may decimate into subpart and access them and we can add some interleaving bits
but since in fpga i can access only in one by one element right?
so how the conceot changes
(4,584 Views)
I am afraid I don't fully understand you.
Are you asking about specific implementation techniques? It's hard for me to answer since I don't fully understand your specific problem nor your algorithm. And as I said I have never implemented any convolution interleaver in LabVIEW myself.
But if the link I provided matches what you want to do I would probably follow what is depicted in Figure 2. I would take the data from host using a host-to-target FIFO, reading each byte from that FIFO and then send each bit through a case structure with four diffrent cases where each case would correspond to a different delay. Or something like that.
Figure 2 – Simplified convolutional interleaver architecture.
(4,578 Views)
