FPGA DIO compile error in the sbRIO_9623
I meet the crazy question, when I need to compile new fpga code, two DIO are disable.
for the case, I use many DIO to connect relay, actuator...etc, like DIO 2-30 for example.
How to work?:
I copy the original FPGA VI (like test.vi) to the new FPGA VI (like testB.vi), and the same code.
After compiling FPGA VI, the magic case is happen, DIO 24 and 25 are disable (no action to my relay) and if I switch back original, the action work well again. and present "IF" i create new FPGA VI, only create DIO 24 & 25 and some other port (like 2, 3, 4...), after compiling, the other port are all work done, only DIO 24 & 25 still bad !!
My laptop is windows 7 and LabVIEW2013 sp3 with real-time/ fpga module and I do not remove or install any new NI LabVIEW products recently. by the way, I really forgot what happen in my laptop.
If anyone have similar experiences like me? or could someone give me some advice to test/ find.
PS: I do not receive error message when/ after compiling FPGA code.
Thank you,
Yu-Quan
來自台灣,喜愛學習以及熱衷自造~自得其樂~
Message 1 of 1
(2,961 Views)
