FPGA: Delay on digital input
I've experienced a strange behaviour when reading a digital input of my PCI-7833 FPGA device: What I want to do is to trigger an output on the falling edge of a digital input. To do so I implemented a SCL in which I compare the readings from current and the preceeding loop iterations and trigger the output if the desired transition occured (like in fig.12 http://zone.ni.com/devzone/cda/tut/p/id/2993). The problem is that I get quiet long delays between the transition at the input and the change of the output. Furthermore the delay is not a constant number of clock cylces. I tried different loop rates for the SCL and got the following results: 20MHz -> 210ns delay, 40MHz -> 136ns, 80MHz -> 100ns, 120MHz ->  74ns. Can anybody explain that behaviour or even tell me how to solve that problem?
Matthias
Message 1 of 9
(5,124 Views)
are you sending data back to a Front-Panel on the VI??
Message 2 of 9
(5,113 Views)
Hi
iam using 9004 compact rio controller with NI 9201 analog input module and NI 9401 digital module installed in it.
iam able to receive the analog input from a temperature sensor connected to AIO. if the value crosses a threshold ,i want  to trigger the DIO 0 ,by which i should turn ON a relay and tthus turn ON a cooling fan. i couldn't trigger the digital output by connecting a boolean control ,even if the control is high i am unable to get the output(5v) at the DIO 0 pin.
plz  tell me what to do..
Message 3 of 9
(4,766 Views)
this is the image of my vi.
Message 4 of 9
(4,764 Views)
have you configured the IOs as output with the "invoke method" primitive? They are inputs by default.
Matthias
Message 5 of 9
(4,759 Views)
thanks for the reply,
    to make it simpler i created a new project and i dragged and dropped DIO 0 from the project explorer to the block diagram of fpga vi (inside a while loop)
right clk the i/o node and changed the option from read to change to write... gave a boolean control as input. compiled and run it.. still when i give boolean true as input i couldn'd get the output
do i have to do any other thing..if so kindly attach a image file of what i have to do..
Message 6 of 9
(4,749 Views)
I've just checked the available settings for the 9401 IO-Module. In the project explorer you have to right-click the IO-Module and select the properties entry. Here you can switch between input and output.
Matthias
Message 7 of 9
(4,744 Views)
thanks haefner for your reply, it worked. the options for changing is from DIO7:4 & DIO3:0 ie., the 8 DIO is divided into two sets and each can be configured for input or output.
since iam a beginner kindly answer my following doubts:
-> why can't we individually assign each pin as input or output
->whenever i compile and run the FPGA vi(created under FPGA target in project explorer) and then deploy the host vi(created under crio), it won't deploy successfully, it gives me a communication error,if i click ok then another window will pop up saying "warning:connection with the real time controller has been lost" again if i click ok and deploy again it is successful.why it fails the first time?
     kindly reply
temin
Message 8 of 9
(4,721 Views)
Temin,
I'm happy that I could help you.
Regarding your further questions:
In what way the DIOs can be switch between input and output depends on how the IOs are realised in hardware. I guess the limitation is due to minimizing complexity and costs of the IO-Modul. In principle it should be possible to have an IO-Modul with IOs that can be switched individually between input and output. But I don't have much experience with CRIO. I work with R-Series and FlexRio Boards. There you can switch each IO individually, even at runtime.
Since I don't work with CRIO I cannot help you with your deployment problem - sorry.
Matthias
Message 9 of 9
(4,719 Views)
