FPGA, Embedded, Xilinx, Zinq-7000
1) What kinds of FPGA does LabVIEW support? Which of them for academic use only?
2) If we buy "Xilinx Zynq-7000 SoC ZC702(706) Evaluation Kit" (http://www.xilinx.com/products/boards-and-kits/EK-Z7-ZC702-G.htm) what is needed for programming and debugging in Labview?
3) What is needed for programming and debugging in Labview ARM processor on board Zynq-7000?
4) Acquisition of drivers for each FPGA done separately or included in Labview FPGA and Labview Embedded?
(3,685 Views)
Hi there, unfortunately FPGAs that are not inside of NI hardware can be programmed with NI software.
Alejandro C. | National Instruments
(3,654 Views)
Hi!,
You should definately contact you local sales rep. on this, see if you can get more info.
Though there is no support for Zinq yet, it has been demoed, and last year at NIWeek embedded raodmap session, it was mentioned as still being on the road map for future products.
Cheers
/MArcus
(3,597 Views)
