FPGA Evaluation how many ticks for code section
Dear LV enthusiasts,
Is there any way to determine how many ticks are needed for the execution of a for-loop or a VI? The code isn't running as fast as required, and I would like to identify the bottleneck. Maybe some simulation?
Thank you in advance!
(809 Views)
Hi e1,
place timing functions in your code to measure the execution time!
(807 Views)
No answer to your question, but...
Put time critical code in a single cycle timed loop.
This ensures it takes 1 tick... It won't compile if it doesn't fit.
(783 Views)
Use the LabVIEW FPGA Desktop Execution Node to get accurate timing in simulation mode.
https://tmesystems.net/
(758 Views)
First time I heart about that...
I'll still stick to the SCTL whenever I can, so I hope I remember this tool if I ever need it.
(730 Views)
