FPGA Host broken when deploying Exe
Hi all,
I am working on a FlexRIO 7954R project with LabVIEW 2009.
The executable works fine on the developpement computer, but when I try to run it on another PXI, with LabVIEW RTE installed, I get error 1003 on Host VI.
On the host VI, the FPGA code is loaded using "Open FPGA VI Reference" with a bitfile path.
Do you have any idea about the reason of the problem ?
Is LabVIEW RTE sufficient , or do I need to install some extra software/drivers?
Thanks in advance.
Cordialement,
Micaël DA SILVA
(3,052 Views)
Accepted by topic author Micael_
Hello Micael_,
Thanks for posting on National Instruments forum.
You should install LabVIEW RTE 2009 and the NI-RIO Driver (with the FlexRIO Support) on the deployment PC.
Can you tell us more about the error you got? Basically, the error 1003 indicates that a VI is not executable.
    Benjamin R.
Senior LabVIEW Developer @Neosoft
(3,036 Views)
Benjamin_R,
Thanks for your answer.
The deployment computer had LabVIEW 8.6 FPGA installed, but I think the RIO driver was too old for LV2009 RTE.
I updated it to NI-RIO 3.2 and now my LV2009 exe is working.
Many thanks
Cordialement,
Micaël DA SILVA
(3,030 Views)
