FPGA IP integration node wizard freezes with *.edf import
Hello everyone. I am using LabVIEW 2015 SP1 32bit f 10 Patch, LabVIEW FPGA 2015 SP1 and Xilinx Vivado 2014.4 f2 (windows 7 64 bit)
My task is to integrate the IP block using the IP integration node. IP block format: *.edf (in attachments). This is a CAN bus handler.
This is where the process stops!
Log:
Generating simulation model for this IP...
****** Vivado v2014.4_AR66772_AR65813_AR64601_AR63880_AR63479_AR62969_(AR63524_AR64594) (64-bit)
**** SW Build (by xbuild) on Tue May 19 17:22:27 MDT 2015
**** IP Build 1070531 on Tue Nov 18 01:10:18 MST 2014
** Copyright 1986-2014 Xilinx, Inc. All Rights Reserved.
source {C:\\NIFPGA\\iptemp\\ipin2B59EC07395249B6BD3D17134315A5E5\\Vivado\\init.tcl}
# read_edif {C:\NIFPGA\iptemp\ipin2B59EC07395249B6BD3D17134315A5E5\Vivado\CAN_IP_DLW30.edf}
# set_property PART xc7k410tfbg900-2 [current_project]
# link_design -name MyDesign -top [find_top]
Design is defaulting to srcset: sources_1
Design is defaulting to constrset: constrs_1
Design is defaulting to project part: xc7k410tfbg900-2
Parsing EDIF File [./CAN_IP_DLW30.edf]
Finished Parsing EDIF File [./CAN_IP_DLW30.edf]
INFO: [Netlist 29-17] Analyzing 6 Unisim elements for replacement
INFO: [Netlist 29-28] Unisim Transformation completed in 0 CPU seconds
INFO: [Project 1-479] Netlist was created with Vivado 2014.4_AR65813_AR64601_AR63880_AR63479_AR62969_(AR63524_AR64594)
Loading clock regions from C:/NIFPGA/programs/Vivado2014_4/data\parts/xilinx/kintex7/kintex7/xc7k410t/ClockRegion.xml
Loading clock buffers from C:/NIFPGA/programs/Vivado2014_4/data\parts/xilinx/kintex7/kintex7/xc7k410t/ClockBuffers.xml
Loading clock placement rules from C:/NIFPGA/programs/Vivado2014_4/data/parts/xilinx/kintex7/ClockPlacerRules.xml
Loading package pin functions from C:/NIFPGA/programs/Vivado2014_4/data\parts/xilinx/kintex7/PinFunctions.xml...
Loading package from C:/NIFPGA/programs/Vivado2014_4/data\parts/xilinx/kintex7/kintex7/xc7k410t/fbg900/Package.xml
Loading io standards from C:/NIFPGA/programs/Vivado2014_4/data\./parts/xilinx/kintex7/IOStandards.xml
Loading device configuration modes from C:/NIFPGA/programs/Vivado2014_4/data\parts/xilinx/kintex7/ConfigModes.xml
INFO: [Project 1-570] Preparing netlist for logic optimization
INFO: [Opt 31-140] Inserted 108 IBUFs to IO ports without IO buffers.
INFO: [Opt 31-141] Inserted 106 OBUFs to IO ports without IO buffers.
INFO: [Opt 31-138] Pushed 0 inverter(s) to 0 load pin(s).
INFO: [Project 1-111] Unisim Transformation Summary:
No Unisim elements were transformed.
link_design: Time (s): cpu = 00:00:08 ; elapsed = 00:00:13 . Memory (MB): peak = 524.797 ; gain = 338.984
# write_vhdl -mode funcsim {C:\NIFPGA\iptemp\ipin2B59EC07395249B6BD3D17134315A5E5\Vivado\CAN_IP_DLW30.vhd}
INFO: [Common 17-206] Exiting Vivado at Sun Dec 24 23:11:53 2023...
I have another computer: windows 10, LabVIEW 2021 SP1 32 bit. This IP block compiles normally there:
Log in attach.
I conclude that everything is fine with the IP block code, the problem is in the vivado configuration or something. Who has any ideas why the code is not being generated?
Message 1 of 1
(961 Views)
