FPGA Image for USRP X410 fails to populate on NI-USRP Configuration Utility
i tried to configure the NI-USRP for the device USRP X410 using the guide https://www.ni.com/docs/de-DE/bundle/usrp-x410-getting-started/page/getting-started.html. Unfortunately, the filesystem cannot be updated after mender committing. You can see in the screenshot Mender_access.png. I use PCIE 8398 and 1Gbit Ethernet Cable.  Inspite of it, the fpga image on NI-USRP Configuration Utility cannot populate automatically.
Do you have any solutions to fix these problems?
Thank you!
Olivia
(1,461 Views)
Hi
Do I have the same problem, or have you already found a solution?
I will be very grateful for any help in this matter.
Mirek
(1,167 Views)
Hi
 I have the same problem, have you already found a solution?
Best regards
 Mirek
(1,147 Views)
If the FPGA image fails to populate, please do the following:
I was able to locate the FPGA image at C:\Program Files\NI\LVAddons\niusrprio\1\instr.lib\niUSRP\Reference FPGA\FPGA Bitfiles
Manually search your PC for the FPGA image and load it into the NI USRP Configuration Utility.
There are a total of 4 types of images in this folder, which can be used depending on the application.
(1,019 Views)
