FPGA Indicators
Hello all
I know in order to optimize the speed the FPGA can run, I need to limit the amount of indicators on the FPGA front panel and use DMA FIFOs where appropriate. Where I'm confused is I am unsure at what data size it is more efficient to use a DMA FIFO. I have 13 indicators in my FPGA code, and am not sure what data transfer mechanism to use. Thanks.
(3,433 Views)
Accepted by topic author Schrodinger1933
There are two main methods to transfer data from your FPGA to RT target - front panel controls/indicators and DMA FIFOs. DMA FIFOs are going to be the fastest method if you are transferring large amounts of data between FPGA and RT, while front panel control/indicators will be dependent on the speed and availability of the host processor and are better for small/infrequent data transfers.
For more information on these two methods, I would consult the cRIO Developer's Guide (starting on page 89).
https://www.ni.com/en/forms/compactrio-developers-guide-full.html
Additionally, here is a help document for optimizing FPGA VI speed.
https://www.ni.com/docs/en-US/bundle/labview-fpga-module/page/optimizing-fpga-vis-for-speed-and-size...
(3,384 Views)
