FPGA Interface C API, error -63105, NI-RIO: The C/C++ identifier is already in use and could not be created.
Hi
Setup:
1x NI PCIe-7841R
When I am trying to auto-generate a C++ API for my FPGA top VI using FPGA Interface C API 12.0 I get the following error.
Error -63105
NI-RIO:
The C/C++ identifier "NiFpga_FPGATop_IndicatorBool_DMAFIFOtimeoutoccured" is already in use and could not be created.
Does anyone know what this means? Is there some kind of limitation on the naming of front panel interface controls?
/mola
(2,748 Views)
Accepted by topic author mola
Problem solved.
I had placed two indicators with the same name on the front panel - by mistake. It builds the FPGA without errors, but the C API generator did not support this.
/Mola
(2,729 Views)
