[FPGA LV16] Xilinx FIR Compiler Block Error: " -4702 Error occurred during regular expression match."
I have trouble with compiling a simple FIR Core (configuration does not matter) for an NI 7975R Kintex7 Fpga with Labview2016 and Vivado 2015.4 on Win7 x64. When I compile the same core for an Virtex-5 Fpga (using ISE 14.7 compile Tools), it works without complaints.
Looks like there is something broken in the Interface between the Core-Compiler from Xilinx and Labview... but I have no clue how to solve this. The configuration of the Core does not matter, it doesn't compile any other Blocks like the Accumulator-Block as well. I think I have the latest SW from Labview Update Service regarding FPGA Tooling.
Currently, I have no possibilities to use our NI 7975R FPGAs...
Any Suggestions how to solve that issue?
Best regards
(3,103 Views)
did anyone had that or a similar error? anything to try / verify / check?
(3,054 Views)
Surprised nobody responded (or even from NI).  I have been getting similar issues with the FIR Compiler block.  It is as if the block forgets its configuration.
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(2,685 Views)
