FPGA LVDS Output
I'm wondering if there is the ability to configure the output type of digital IO pins on an FPGA. I have the PXI-7854R, and I think when I use a resource as an output I get 3.3V. But I'm curious if I can get 5V or if I can configure two pins for an LVDS input or output?
Kevin Key
(3,513 Views)
Hi.
No, you cannot configure the DIO Pins for another voltage. But you could use the Analog Outputs for LVDS.
Christian
(3,496 Views)
