FPGA Memory errors when building...
I am building an FPGA application for an sbRIO-9636. I just added a memory item to act as a circular buffer.
The memory item has the size set to 414000 U8 items. When I build I get an error in the compilation status window that starts like this.
"LabVIEW FPGA: The compilation failed due to a Xilinx error.
Details:
ERROR:sim - User configuration exceeds BRAM count in the selected device
ERROR:sim:963 - IP initializer could not set IP core parameters on IP model
ERROR:sim - Failed to initialize IP model.
ERROR:sim - Failed executing Tcl generator.
ERROR:sim - Failed to generate 'ReallyLongUniqueName_ReallyLongUniqueName'. Failed executing Tcl generator.
ERROR:sim:877 - Error found during execution of IP 'Block Memory Generator v7.3'
Release 14.7 - Xilinx CORE Generator P.20131013 (nt) Copyright (c) 1995-2013 Xilinx, Inc. All rights reserved.
I have attached the entire error read out.
Please help!
John O'C
Staff Test Systems Engineer
Woodward, Inc.
Skokie, Illinois, USA
"Life is not a journey to the grave with the intention of arriving safely
in a pretty and well preserved body, but rather to skid in broadside,
thoroughly used up, totally worn out, and loudly proclaiming...
Wow...What a Ride!"
(6,109 Views)
Accepted by topic author johnoc
I just realized why I am seeing this error. The sbRIO-9636 comes with 2,088 kbits of Block RAM. I missread the amount as 2,088 kbytes of block RAM, Me wanting to use 414000 bytes will not work.
Thanks to anyone looking into this.
John O'C
Woodward, Inc.
Wow...What a Ride!"
(6,101 Views)
