FPGA SCTL & NI 9474
I understand from http://zone.ni.com/reference/en-XX/help/370984R-01/criodevicehelp/crio-9474/ that NI9474 supports SCTL.
However, I cannot build the FPGA VI as there are errors (pointing to the FGPA I/O method node and FPGA I/O node is not allowed in SCTL).
Once i changed the SCTL to while loop, the FPGA VI is able to be compiled.
I am using Labview 2012.
Any advice?
(2,382 Views)
Have you configured the output synchronizing registers and confirmed in your code that the module is ready to output (info in the link you provided)?
Chris
Certified LabVIEW Architect
Certified TestStand Architect
(2,376 Views)
