FPGA VI Compilation Failure
I have issues with trying to compile an FPGA VI. It was able to compile previously until I made a few changes. I added in another memory block and created two extra sub VI which are used to read and write from the said memory block. I also had to rewire a node as it was incorrectly wired before. After making these changes it produces two errors as shown in the attached xilinx log file. I should also mention that I have no trouble comiling other FPGA VIs, its only this particular example in which the process fails.
Any advice on fixing this problem is greatly appreciated, thanks!
(3,518 Views)
We need to see code.  It is likely some really small detail that you missed.
(3,481 Views)
Two errors are saved and both are indicating a range problem. Look at your memory which is configured with 9 or 10 elements.
Could be an initialization problem. You could init your memory from the project properties. Check if you try to access an element outside of the specified dimension/range.
ERROR:HDLCompiler:1318 - "C:\NIFPGA\jobs\OQ01h29_W30F9T1\NiFpgaAG_0000001a_CustomNode.vhd" Line 101: Left bound value <10> of slice is out of range [9:0] of array <ctoresport>
Netlist NiFpgaAG_0000001a_CustomNode(17,10,32,512,16,2,33,-61220,0)(rtl) remains a blackbox, due to errors in its contents
Elaborating entity <FPGAwMemoryn6> (architecture <rtl>) with generics from library <work>.
ERROR:HDLCompiler:410 - "C:\NIFPGA\jobs\OQ01h29_W30F9T1\FPGAwMemoryn6.vhd" Line 100: Expression has 8 elements ; expected 9
Netlist FPGAwMemoryn6(27,1,10,17,512,16,0,0)(rtl) remains a blackbox, due to errors in its contents
Hope it helps
Christian
(3,453 Views)
