FPGA and TMDS files
I'm working in real time with the cRio 9074 system in mode FPGA having the module ni 9234 to get acceleration. My problem is that I already elaborate the VI in the labview using RT FIFO and TDMS files to save the data. the VI doesnt make any mistakes when all the information is save but it doesnt generate the archives TDMS and also the program doesnt show the graphics when you are using it
(2,635 Views)
You should post screenshots of your code (or LV code itself) because it is not possible to help you with so few information.
(2,612 Views)
You need to explain a lot better.  Are you seeing this issue when running in the LabVIEW IDE or when you deploy?
Are any errors being generated.  The most common issue I see here is people try to save the data from the cRIO by giving it a path of C:\blah\data.tdms and then wonder why the data is.  The cRIO is its own computer.  So you need to treat it like one.  It does not have access to any drives on your computer.  You have to save it off on the cRIO or give it a network path that it can write to.
(2,597 Views)
Spoiler
Add VI project thanks
(2,587 Views)
