FPGA and VGA
I suppose it is possible to use FPGA to generate VGA signals to control a VGA monitor or projector. Here is a way:
https://forums.ni.com/t5/Example-Code/VGA-Device-Driver-for-FPGA-Applications/ta-p/3504312
But it requires that the target must have a VGA port (for example, Spartan-3E Starter Board).
Here comes my quesiton,
Is it still possible to do so on a borad that does't offer a VGA borad, say myRIO. I've learned that myRIO has reconfigurable IO technologies which we might take advantage of. So how do I implement a VGA drive on myRIO, with labview FPGA? Expecting responses.
myRIO specifications attached.
https://www.ni.com/docs/en-US/bundle/myrio-1900-getting-started/resource/376047d.pdf
Thanks.
(4,253 Views)
Hi
There are a couple of reasons you cannot do VGA output with myRIO
1) VGA requires 3 Analogue Outputs, one for each of Red, Green and Blue.
2) The bandwidth of these signals is too high for myRIO as well. You need 640*480*60Hz samples/s to fulfill a true VGA image. At 345kHz the Analogue output of the myRIO isn't going to cut it.
Sorry
Mike
(4,211 Views)
Well, thank you
(4,199 Views)
So you can't drive a VGA display, but you can use the SPI/I2C/UART communication to display some feedback to the user in the form of a LCD display.  I would link to the demo on Youtube but apparently I'm not allowed to because of a word that is in the link that is not allowed, just search NI myRIO: LCD character display on youtube.
This would allow the myRIO to run headless without needing a PC to talk to.
(4,180 Views)
