FPGA code for reading data from NI9211
Dear All
does any one have any FPGA code to read and manipulate the data out of an NI9211 in order to use it as a thermocouple? Something that reads the data and convert it to degree Celsius.
I know you can use it to measure temperature in Scan mode very easy, but I need to program my codes in FPGA mode.
Thank you
(3,493 Views)
Hi amir_aj,
Have you tried looking at any of the examples?
In LabVIEW go to Help -> Find Examples then search for the NI 9211 Getting Started.lvproj
The description for this states that the example demonstrates how to acquire, calibrate, and display thermocouple measurements using an NI 9211 module.
Hope this helps!
Tori
Student
(3,437 Views)
Thank you Tori,
I had a look there and found my answer!
(3,435 Views)
