FPGA code for use with NI-SCOPE (NI-517x)
I am trying to configure a PXIe-5170R oscilloscope using NI-SCOPE and a specific FPGA bitfile. I compile some bitfiles that work properly with the Multirecord Acquisition sample project. When I try to load them using the NI-SCOPE initialize with options.vi I get an error referring to the address space. I don't know how to go about fixing this error.I found an example (https://www.vipm.io/package/ni_example_517x_abtrig/) that loads a bitfile and uses NI-SCOPE, but it unfortunately doesn't include the FPGA code (and I get an error referring to the configuration library when trying to run the example).
Has anyone been able to use a specific bitfile with NI-SCOPE, and would be able to share the FPGA code?
Thanks!
Message 1 of 1
(1,925 Views)
