FPGA: compilation error: size of concat operation is different than size of the target
Today I got an error, for which I couldn't find a solution.
I use the PXI-7813R FPGA, with Xilinx tools 10.1
At compilation, the error I get is:
Compilation failed due to a Xilinx error.
Details:
ERROR:HDLParsers:804 - "C:/NIFPGA/jobs/TESY1S8_X4PR8hn/NiFpgaAG_000000ce_CaseStructureFrame_0000.vhd" Line 301. Size of concat operation is different than size of the target.
ERROR:HDLParsers:804 - "C:/NIFPGA/jobs/TESY1S8_X4PR8hn/NiFpgaAG_000000ce_CaseStructureFrame_0000.vhd" Line 372. Size of concat operation is different than size of the target.
Total memory usage is 185944 kilobytes
Number of errors   :    2 (   0 filtered)
Number of warnings :    0 (   0 filtered)
Number of infos    :    0 (   0 filtered)
Process "Synthesis" failed
Start Time: 18:25:26
End Time: 18:28:54
Total Time: 00:03:27
What can cause a concat size difference?
Message 1 of 12
(5,572 Views)
I deleted some non-trivial FIFO related stuff and suddenly worked again. Although I ain't sure if that was the reason.
Message 2 of 12
(5,566 Views)
No, it appeared that wasn't the reason. After some minor modifications, a recompile was necessary.
First, I got an unexplained error. No error code. That the vi was not in a state for compilation, (have seen this before and is then often marked as error code 1000).
Second, I opened all my subVIs and made minor movement on a single indicator to force recompiling of the subVIs.
Third, at rebuilding, the same error occured:
Details:
ERROR:HDLParsers:804 - "C:/NIFPGA/jobs/IBj6Ib7_X4PR8hn/NiFpgaAG_000000ce_CaseStructureFrame_0000.vhd" Line 301. Size of concat operation is different than size of the target.
ERROR:HDLParsers:804 - "C:/NIFPGA/jobs/IBj6Ib7_X4PR8hn/NiFpgaAG_000000ce_CaseStructureFrame_0000.vhd" Line 372. Size of concat operation is different than size of the target.
Total memory usage is 185688 kilobytes
Start Time: 17:36:10
End Time: 17:39:38
Total Time: 00:03:28
Any suggestions on solving this error?
Message 3 of 12
(5,559 Views)
This is by the way the configuration:
Project: FPGAWrapperMG100125AOD.lvproj
Target: FPGA Target (RIO0, PXI-7813R)
Build Specification: fpga_integrator_AOD_random_access
Top level VI: fpga_integrator_AOD_random_access.vi
Compiling on LabVIEW FPGA Compile Cloud Service
Compilation Tool: Xilinx 10.1
Start Time: 05.07.2011 19:06:12
Run when loaded to Fpga: FALSE
Xilinx Options
Design Strategy: Custom
Synthesis Optimization Goal: Area
Synthesis Optimization Effort: Normal
Map Overall Effort Level: Default Xilinx setting
Place and Route Overall Effort Level: High
JobId: FNW72uPWorking Directory: C:\NIFPGA\compilation\FPGAWrapperMG100_FPGATarget_fpgaintegratorAO_9D5B4237
The Xilinx log is attached.
Message 4 of 12
(5,553 Views)
HI Harlequinade,
it seems that the problem could come from a case structure from the message. However it may not be a problem with the case structure but its content.
Could you post your FPGA VI so I can take a look at that?
Joseph Tagg
Message 5 of 12
(5,535 Views)
The project is a bit large and complex. Is it okay if I can send it to you personally?
Message 6 of 12
(5,530 Views)
have you tried as I suggested with a local compile server?
Does that help?
Joseph
Message 7 of 12
(5,500 Views)
Local and remote compile server doesn't seem to make a difference.
When things don't compile here, we use the magic trick to force recompile, which is the following work-around.
i) open all subVIs & controls
ii) move a control on FP or BD by a pixel and save each file
iii) try to compile again
Message 8 of 12
(5,442 Views)
You can also force a recompile by holding Ctrl and clicking the Run arrow. Doing so will force a compile but will not start running the VI when the compile is complete.
Message 9 of 12
(5,434 Views)
True, but it somehow doesn't force the FPGA compiler to see the subVIs as changed.
I tried it, but it didn't help me. Changing all VIs and clusters saved in controls did the trick for me. I'm just writing it down, such if someone has the same problem, he/she could try this out.
Message 10 of 12
(5,432 Views)
