FPGA - compilation failure
Hello all, I'm studying labVIEW FPGA. When I tried to run my first FPGA program, the compilation always failed. Please see attached picture for details.
PCI-7830R is installed and works properly in my PC.
The software I installed -
labVIEW 2010
FPGA module 2010
xilinx 10.1 (I did not install version 11.5 since I got information from http://digital.ni.com/public.nsf/allkb/ed6fc9cf7b983cfd86256dce0072e313?OpenDocument)
Above software are evaluation version.
Does anyone know the cause of the failure? Thanks in advance for your comments.
(3,105 Views)
As long as the VI's are that simple, simulate them first.
To do that right click the FPGA target and select Execute VI on -> Development Computer with Simulated I/O.
br Christian
(3,087 Views)
Hello Christian, thank you so much for the comments. Yes, you are right. This time I follow you suggestion to simulate the VI as below, it can work. However it still can not pass compilation. It shows the same failure as I mentioned above.
Thanks again for your help,
Cole
(3,071 Views)
I think the error is not caused by your code.
I would try to reinstall the xlinx compiler, but first check if the reported libGenXstTask.dll exists under the specified path.
br Christian
(3,059 Views)
