FPGA compilation gives windows error
Hi All,
I am facing with a weird issue.
I have a FPGA code which i compiled (from labview) last week. I faced no issue. Compilation happened very well without any issue.
When i tried compiling the same code yesterday, it gives windows error (Please see the attached error.bmp).
Please let me know what could be the possibilities for this weird behaviour.
I have also attached the report generated after this window error happened.
Your help is greatly appreciated!
Muthuraman S
Muthuraman
(3,042 Views)
Are you getting the same error every time you try to compile the code? Have you made any changes to the code especially to the usage of clocks?
(3,015 Views)
Yes, I am getting the same error every time i compile. And there is no change in code at all. Same code while compiled well earlier is giving this error now.
Muthuraman
(3,011 Views)
Can you try something? Just make a new project upon the same FPGA target and create a new VI. Just copy paste the block diagram code from your old VI to the new one and try recompiling it. Please let me know if you receive the same problem. And also, are there any other factors causing LabVIEW crash, apart from FPGA compile? As in, have you faced this crash at any other scenario, when you were not trying to compile FPGA code?
(3,009 Views)
