FPGA compile server - missing compile farm console
System:
LabVIEW 2011 SP1
Xilinx 12.4 SP1
I'm working through this white paper on FPGA compile farm setup ( http://zone.ni.com/reference/en-XX/help/371599N-01/lvfpgahelp/fpga_gettingstartedfpgacompilefarm/ )
In the section titles Setting Up the Compile Workers, I can do everything except for step 3. When I login into the compile server, I don't see that FPGA Compile Farm Console button. Even though I'm compiling locally, shouldn't this option be available if I have the correct software installed? What does this mean if I don't see it on there (what do I need to install)?
Thanks in advance.
(3,042 Views)
Hi sjacksonPA,
Did you see the button that had that icon or one similar to is on the page after logging in to the compile server?
It might be a little subtle but I believe it should be there on the login page.
David
(2,999 Views)
