FPGA compiler worker
The FPGA compilation time in a more powerful computer turned out to be slower.
I read before that the FPGA compiler does not take advantage of multi core processors, but it still does not make sense to me.
I set the process to be high priority and affinity.
Any comments?
Thank you
Computer1: 16 minutes (average)
Computer2: 18 minutes (average)
Computer 1:
- Windows XP 32
- Intel T9400 @2.53GHz Duo
- 4G RAM
Computer 2:
 - Windows 7 64
 - Intel Xeon X5690 @3.47GHz Quad
 - 24G RAM
(3,223 Views)
mjochinsen,
Which version of the compile tools are you using? Are you compiling the exact same code?
(3,172 Views)
There's a trick here for significantly speeding up the compilation process on certain CPUs: http://forums.ni.com/t5/LabVIEW-FPGA-Idea-Exchange/Multi-core-Compiling/idc-p/2301338#M297
(It looks like your CPU is supported)
(blog)
(3,164 Views)
