FPGA create variable crash
crio  9014, 9114 chasis, labview 11
If I create a lvlib under the 9114 chasis FPGA target and then click "create variables" in that library, whenever I click ok to create the variable it will crash to the desktop.
I found this issue in my current project but if I create an new blank project I get the same result.
(3,421 Views)
Hey Eric,
I tried to reproduce the behavior you were describing on my end and I was not getting the same result. I was able to create the variables from the lvlib under a 9114 FPGA target. This leads me to believe that the issue might be with your LabVIEW FPGA module. I would try to repair that module and see if that solves your issue.
Hope This Helps,
Doug B
(3,401 Views)
I have installed sp1 for labview 11 , still crashes
did a repair of the fpga module (from programs in control panel?)
Still crashes
(3,371 Views)
Hey Eric,
Check your services to see if your Shared Variable Engine is running. The other thing I would suggest is to try and programmatically create your shared variables and see if you get the same behavior. Here is a good example you might be able to use to test this:
https://decibel.ni.com/content/docs/DOC-12548
Hope This Helps,
Doug B
(3,361 Views)
Shared variable service is running.
Running the sample project you linked to work properly, a new variable was created without issue.
I am not using them in my current project, so its not a critcal issue for me yet.
(3,355 Views)
