FPGA custom trigger for PCIe 5763
Thank you for all the insight. I will try to modify the streaming api and see what I can get done. I will also look into getting a state machine into the FPGA code!
Message 11 of 13
(186 Views)
For anyone wondering... I edited the Data Stream Control vi (FPGA) . I edit the stream it enters after finishing a finite transfer. After a finite transfer is finished the stream state goes into a "Done" state which then switches the case structure diagram into "Done". Inside the "Done" case structure there a sub case structure with inputs being "Idle" and " Finite Transfer and Continuous" Inside the "Finite Transfer .... " case structure  the stream state stays in "Done " state so I switched the "Done" state to "Idle" so it restarts the Finite transfer through the FPGA. On the host side I added logic to compensate for this.
Message 12 of 13
(178 Views)
Good to hear.
Since this is a common LabVIEW FPGA library, I assume this gets copied and pulled into the project specific code.
If possible, it may be good to look into contributing this to the NI LabVIEW FPGA github repo: https://github.com/ni/labview-fpga-examples
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
Message 13 of 13
(170 Views)
