FPGA deployment on VST- what do I need?
I'm deploying a project including custom FPGA code to a Vector Signal Transceiver system. The host operating system is Windows. What do I need to install for runtime support? (i.e. no LabVIEW development install)
(2,788 Views)
Accepted by topic author ToeCutter
Hi ToeCutter,
In order to run the VST application on the machine without LabVIEW development installed, you will need to install:
1. NI RF Device Drivers
http://www.ni.com/download/ni-rf-device-drivers-2014.03/4671/en/
2. LabVIEW Run-Time
In your project you can build an installer and configure it to include the LabVIEW run-tim.
Here is a quick tutorial:
Building an Installer (Windows)
http://zone.ni.com/reference/en-XX/help/371361H-01/lvhowto/build_installer/
I hope that you will find it useful.
Kind Regards,
(2,731 Views)
Thankyou for the detailed response, Max. Much appreciated!
(2,723 Views)
