FPGA - how to set array to zero
I use a signal filtering subVI applied on a fixed size array. Depending on cRIO configuration, I use different fixed size array.
The thing is that I need to initialize filters with zeros. As maximum effectiveness in resources usage is required, I want to know how to get the fixed size array and set it to zero with most efficient way. Ideas that come to my mind:
Multiply by zero
Bit shift right 32 times (datatype I32)
Size of fixed size array is constant -> wiring "array size" output to initialize array (not working, size of fixed size array is not considered constant)
(5,330 Views)
Or maybe subtract array from itself
(5,311 Views)
Another idea: xor the array with itself.
I doubt there will be a significant performance difference between initialization methods. If the compiler recognizes the pattern, it should optimize it to a constant.
(5,299 Views)
use a memory item in the FPGA: here you can define intial values…
(5,295 Views)
Do you need this during run-time or only at startup?
(5,280 Views)
I did some testing and both multiplication by zero and subtracting the array from itself works in a single-cycle timed loop. This means you can do the initialization in the timeframe of one click.
(5,260 Views)
Or just create a constant and use a select primitive.
(5,251 Views)
